13-06-2012 #12
If there is play in the machine, then climb cutting can cause a sudden jerk, and climb cutting will self feed. However, the cutter is still pushing the work away. Looking at your picture, the cutter enters the work almost perpendicular. The forces are pushing the tool away, but since it has nowhere to go, it appears to grab. If the cutter was actually pulling the work toward it, it would dig in. Instead, it rides along the edge.
Try this. Program two identically sized squares, and cut one with a conventional cut, and one with a climb cut. The climb cut will always be slightly larger, because the bit is pushing away from the material. With the conventional cut, the bit is pulling into the material, resulting in a smaller part. A lot of shopbot users use this to their advantage when cutting cabinet parts. They do a "rough" climb cut sluightly oversize, then finish with a conventional cut. By removing a very small amount with the conventional cut, it minimizes the effect of the bit being pulled into the parts.
Wood cnc router for hobbyist
By nerostjames in forum Machine DiscussionReplies: 9Last Post: 01-01-2018, 09:28 PM -
Conventional & Climb milling code
By JAZZCNC in forum Programmers CornerReplies: 0Last Post: 19-12-2012, 07:12 PM -
BUILD LOG: Wood Router
By Buba b in forum DIY Router Build LogsReplies: 18Last Post: 03-10-2012, 09:49 AM -
Types of Ballnut and preload, questions - pros & cons ?
By Jon S in forum Lead Screws, Nuts & SupportsReplies: 1Last Post: 16-01-2012, 03:39 PM -
NEW MEMBER: Wood Lathe - fitments
By Musochasle in forum New Member IntroductionsReplies: 16Last Post: 10-08-2010, 08:28 AM
