10-06-2012 #24
Try with the printer port driver installed. A lot of things in Mach3 don't work correctly without it.
Also, I'm not sure if everything will work correctly using a VM. I don't think you can run a machine with Mach3 through a VM. At least I've never heard of anyone doing it. And if it's not fully functional, it's not a valid test.
One thing you might want to try is install 3.42.040 first, then install 3.43.062 on top of it. It doesn't crash here with 3.43.062.
You did say that it only crashes from the probe wizard toolbar button, right? What if you click the wizard button, then choose the probing wizard?
As I mentioned above, if you do a toolchange with that version, it may cause Mach3 to lockup, which requires a hard reboot to recover.
"Hacking" and "Modding"
VFD problems, please help. error code "DL"
By humbo3d in forum Spindles & Drive MotorsReplies: 0Last Post: 06-02-2014, 05:49 PM -
MACH 3 2010 Screenset Zeroing Macros
By Washout in forum Artsoft Mach (3 & 4)Replies: 5Last Post: 12-01-2014, 01:15 PM -
Interesting Article "Makers unite - the revolution will be home-made"
By Fivetide in forum General DiscussionReplies: 4Last Post: 28-09-2012, 12:06 PM -
"Racks" VS "ball screw"
By C.AlveSilva in forum Linear & Rotary MotionReplies: 1Last Post: 17-04-2012, 11:53 PM
