Thread: Good or bad idea? Concreate!
08-06-2012 #4
Not sure which bits your meaning on 3040 to fill but I've got the slightly smaller 3020 here and the only part of the machine that could be filled is the bed extrusion.!
No way will you get concrete or Epoxy granite down the small extrusion holes due to the aggregate size, Epoxy alone won't had much resonance dampening or weight.
The thing you could and I would do is cap seal the extrusion at one end then pour kiln dryed sand into then cap and seal the other end. This way you can empty the extrusion if need be for moving about.!! . . . Far better and really simple has the extrusion end is pre drilled ready for tapping for bolts to hold the caps.
Sand is a brilliant resonance dampener and heavy.!!
Website idea.
By qwertyjon in forum General DiscussionReplies: 18Last Post: 11-07-2014, 08:49 PM -
Here's an idea hacking a Kress 1050 FME
By m.marino in forum Kress Milling MotorsReplies: 3Last Post: 16-01-2013, 01:05 AM -
Cheap Idea for a DRO
By 1113562 in forum General ElectronicsReplies: 70Last Post: 27-02-2011, 04:20 PM -
BUILD LOG: Mel's Odd Idea
By mel_earp in forum DIY Router Build LogsReplies: 3Last Post: 19-03-2010, 11:54 AM
