Thread: Stepper Motor Power Question
	17-07-2012 #1
OK I'm pretty much a newbie so far as building is concerned. I'm putting together my first gantry router loosely based on http://www.instructables.com/id/DIY-CNC-Machine-36x22/ for use on wood and Sikablock type products. Being a tight-wad I have chosen to use stainless steel all-thread drive screws with double anti-backlash nuts made from Delrin using my vintage Myford S7. Having a Halda gram gauge I'm thinking of being a bit scientific by using it to determine the force at a given radius (and hence the torque) required to start the lead-screws from rest. From this I'm hoping to determine the minimum torque I need from the stepper motors which I have yet to select. What I'd like to ask the panel is "What sort of allowance over that which the Halda tells me would you recommend?".
No longer lurking, stepper motor question.
By simonparkes in forum Stepper & Servo MotorsReplies: 8Last Post: 26-03-2014, 11:52 AM -
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
motor power and chinese spindles power HELP
By DigiSoft in forum Spindles & Drive MotorsReplies: 5Last Post: 17-09-2013, 12:17 AM -
Calculating Stepper Motor Power? Strength?
By antsals in forum General DiscussionReplies: 2Last Post: 11-07-2011, 12:18 PM -
common wire on stepper motor question
By progomez in forum Motor Drivers & ControllersReplies: 1Last Post: 27-10-2009, 11:56 PM
