10-06-2012 #7
Well got the Gerrys 2010 screenset, installed it as per the manual, and got to say that it looks much nicer than the original Mach screen. A lot easier to navigate around, took me about 5 mins to get my head round it.
Still not bothered with the homing switch's and I have got the auto tool length setting working just fine without them, I will be putting them on at some time soon though. Set up and tested my soft limits and they should give me enough protection at this stage.
Quick question - In the Auto Zero settings, can I set the tool using my height probe on the bed of the machine, put the height of the probe into the plate thickness box (41mm in my case) and then put the distance from the bed to the top of the job (Z0) in the material offset. This is more or less the same method that I have used on larger CNC machines in the past, only difference is the G54 Z offset is not used and the figure in the material offset box is used in its place. The simple auto zero button seems to achieve this but not played enough yet to see if the material offset workaround will work or not.
Theory behind this is quite simple, if i tell the machine how far the top of the work is from the bed by measuring it then the machine only needs to know where the tool is in relation to the bed. For a lot of my jobs I tend to be cutting rough sawn hardwoods which first need facing to give me a flat surface to work on and I usually set my z0 lower than the top surface as it is so uneven. This means setting zero on the top is no good to me.
JAZZ, let me know where you want the £6.64 sending and I will sort it tomorrow.....
Probe Centering with Mach3 Tutorial
By Ricardoco in forum Probing, Digitizing & ScaningReplies: 9Last Post: 02-07-2016, 07:19 PM -
Help Please With Auto Tool Height Mach 3 Problem
By howser37 in forum Probing, Digitizing & ScaningReplies: 26Last Post: 12-06-2014, 07:55 PM -
another tool hight setting proble :)
By blackburn mark in forum Tool & Tooling TechnologyReplies: 4Last Post: 08-09-2012, 11:30 PM -
Problem with height setting in artcam express.
By don_jarr in forum ArtcamReplies: 4Last Post: 07-11-2011, 03:26 AM -
Setting Z height with an ER32 collet
By Robin Hewitt in forum Machine DiscussionReplies: 0Last Post: 27-03-2010, 09:16 PM
