Kevin,
Fairly straightforward once you know how...
Your motors are 200 steps per rev with the drivers set on 1/8th step, this means you have 1600 steps per rev. (200 steps x 8 microsteps).
Lead screw is 2mm for 1 turn, mach3 needs to know how many steps for 1 unit (or 1mm).
So, 1600 steps will turn you leadscrew 1 full turn and in your case move your axis 2mm. Therfore 1600 steps divided by 2mm = 800 steps per unit (1mm).
You could easily get away with setting your boards to 1/4 or 1/2 stepping as set at 1/8th stepping with 2mm pitch leadscrew the accuracy will be 0.00125mm per step, change them to 1/2 stepping then each step will be 0.005mm, the less steps you need the better if you ask me... Of course if you change to 1/2 stepping then the steps per unit will need to change to 200. (400 steps per rev divided by 2mm).
The Following User Says Thank You to HiltonSteve For This Useful Post:
Random G-code for testing motor tuning.
By Jonathan in forum Stepper & Servo MotorsReplies: 2Last Post: 30-10-2019, 08:22 AM -
Help withController dip switch settings and Mach3 motor tuning
By liamo1991 in forum Motor Drivers & ControllersReplies: 2Last Post: 15-11-2013, 02:22 AM -
Mach 3 control of DC Brushless motor?
By templecorran in forum Artsoft Mach (3 & 4)Replies: 15Last Post: 18-11-2010, 04:20 PM -
some questions on tuning and motors
By m.marino in forum Stepper & Servo MotorsReplies: 2Last Post: 17-04-2009, 06:55 PM
