Thread: One sided drive?
02-12-2008 #6
You're welcome. I used the Framework program (mechanic.zip) at http://members.ziggo.nl/wolsink/ to do a rough 3D analysis. Although it doesnt allow you to model the supported rail joined to the box section, I simulated it by creating an arbitrary shape comprising a 30mm high, 15mm wide steel block on top of a 40 mm x 30mm box.
One way to counteract the vertical torsion is to make the gantry sides solid and put a diagonal brace from the side to the cross beam. Obviously too big a brace will compromise the vertical work envelope.
Video of CNC machining a double sided part.
By Shinobiwan in forum Woodworking Project ShowcaseReplies: 26Last Post: 17-03-2013, 11:23 AM -
Chain drive
By D-man in forum General DiscussionReplies: 8Last Post: 06-11-2012, 08:30 AM -
chain drive
By jonm in forum Linear & Rotary MotionReplies: 9Last Post: 07-03-2010, 02:36 PM -
4th Axis CAM Software Multi Sided Machining
By alan2525 in forum Computer SoftwareReplies: 0Last Post: 18-02-2010, 12:44 AM -
Double sided machining
By CraftyGeek in forum General DiscussionReplies: 7Last Post: 08-12-2009, 11:04 AM
