Thread: Setting a start point.
	16-06-2012 #1
No doubt this is a really simple question, but how do people usually set a start point?
I apologise is the term "Start Point" is incorrect, and if so, please correct me.
On my machine, my start point is set manually at "X" and "Y" being zero (I.e. in the corner of the workpiece and "Z" being offset so it's at the top of the workpiece. It's a tedious job and leads to an inaccurate starting position at times.
I suspect that a start point which is set regardless of the workpiece would be better and I change the starting position and offset in Cut2d which I use to generate the GCode.
Thanks for your time.
James
CONVERSION: Re-Built a used CNC mill machine to the point of 80%
By dudz in forum Conversion Build LogsReplies: 13Last Post: 20-03-2014, 06:44 PM -
Setting the zero point on a CNC lathe
By Robin2 in forum Lathes, Lathe Rebuilding & ConversionsReplies: 7Last Post: 20-10-2013, 10:37 PM -
Digitizing probe / Point cloud to mesh
By dudz in forum Probing, Digitizing & ScaningReplies: 4Last Post: 07-09-2013, 10:03 PM -
machine cutting sequence, keeps returning to the original point
By luke11cnc in forum Machine DiscussionReplies: 3Last Post: 06-07-2013, 04:48 AM -
Split Point Drill Bits
By Lee Roberts in forum Tool & Tooling TechnologyReplies: 0Last Post: 10-07-2008, 02:06 AM
