Thread: Setting a start point.
17-06-2012 #15
I know exactly what you mean, I used to find this a right PITA because when you produce a G Code you lose the original drawing, in my case a DXF file.
To fix it I rewrote my cutting software to read in the DXF and every circle shows on screen with a little red rectangle in the middle.
Right button the rectangle and it sets machine co-ordinates to the circle centre, left button it and it moves the tool to the circle centre.
I can also click left or right anywhere on the drawing, which is handy to make sure the cut doesn't overhang the billet.
What I do is drill some holes for locating bolts then clear the mill bed of everything.
I have a bunch of 3/4" thick mounts which have a T slot fixing and an offset stud with a female thread. I made 4 of each in M3 M4 M5 M6 and M8.
I locate the mounts by left buttoning rectangles, lock them in place, replace the billet and bolt it down.
If I have clear space and remembered to add a spare circle to the drawing, I pop in a centre hole so I can relocate if I lose position.
Lots of typing but I would not be without it.
When I am not machining the outside of the billet and need to align metal to the bed, I use the 10mm square tool steel bar I inset a few mm deep at the back of the bed. I cut the pocket for it with the mill so I know it is dead square. It has a splash guard holder on the top.
If trying to align to a centre scratch I start light with a centre drill and go progressively deeper with each attempt to erase the old mark. Really need a sensitive drill handle and a pendant for that.
CONVERSION: Re-Built a used CNC mill machine to the point of 80%
By dudz in forum Conversion Build LogsReplies: 13Last Post: 20-03-2014, 06:44 PM -
Setting the zero point on a CNC lathe
By Robin2 in forum Lathes, Lathe Rebuilding & ConversionsReplies: 7Last Post: 20-10-2013, 10:37 PM -
Digitizing probe / Point cloud to mesh
By dudz in forum Probing, Digitizing & ScaningReplies: 4Last Post: 07-09-2013, 10:03 PM -
machine cutting sequence, keeps returning to the original point
By luke11cnc in forum Machine DiscussionReplies: 3Last Post: 06-07-2013, 04:48 AM -
Split Point Drill Bits
By Lee Roberts in forum Tool & Tooling TechnologyReplies: 0Last Post: 10-07-2008, 02:06 AM
