Thread: Which cnc
17-06-2012 #7
It's certainly worth a look. It's better than most, however the X-axis drive is worrying:
'All machines have Ballscrew x axis with rotating ballnut'
Having a rotating ballnut is excellent for good feedrates, but the description and photo appear to show only one ballscrew on the X-axis. This will severely compromise the rigidity of the machine. Think what happens when the tool is cutting towards the ends of travel on the Y-axis - there is a force pushing the gantry, but the support (i.e. the ballscrew/nut) is a long distance away so it will bend and 'rack' the gantry. If you're only cutting MDF then you would get away with it, but it will still limit your productivity and surface finish. For £5k you should be able to do better than that. This is a typical example of the manufacturer trying to save money since it would cost them (very roughly) £250 more to add another ballscrew and motor (has to have another motor as rotating nut).
The only person whose objective is to ensure you have a high quality machine is yourself.
