Thread: LM Rail
25-06-2012 #2
26-06-2012 #3
Hi GTJim
http://stores.ebay.co.uk/FA-SYSTEM_L...34Q2ec0Q2em322
As posted in another thread a while back I've bought a couple of used profile rail and bearing sets from the above link. Been happy with the service and component quality. These are all used, hence the fairly reasonable prices.
If you are patient on ebay you may find cheaper, but if you want to get on with it then have a look through their store.
27-06-2012 #4
27-06-2012 #5
Don't cut it - use the extra length to space the bearings out further. Normally the force on each bearing is inversely proportional to the spacing, so you want to space them out as far as you can (within reason, assuming what they're mounted on is stiff) to reduce the load on each and thus reduce the deflection. I got two 1150mm (hiwin HGH15) rails for my Y-axis, which is only 760mm travel but I wont be cutting the rails.
He's probably used 4 as unlike most of the good rails the SR series does not have an equal load rating in all 4 directions - http://www.thk.ru/cataloguespdf/sr-300e_cc.pdf ... but since you've already bought them I wouldn't worry about it - any profile rail is going to be a huge amount more rigid than the SBR20 rails you currently use.
The Following User Says Thank You to Jonathan For This Useful Post:
DIN rail and fittings suppliers
By Neale in forum Marketplace DiscussionReplies: 5Last Post: 19-05-2014, 10:14 AM -
Tsk profile rail preloads?
By totts in forum Rails, Guideways & BearingsReplies: 2Last Post: 19-04-2014, 07:44 PM -
WANTED: Supported rail. The bigger the better
By r0bsk1 in forum Items WantedReplies: 0Last Post: 08-07-2013, 07:50 PM -
Open Rail, open source linear rail?
By Musht in forum Open Source Designs & PlansReplies: 0Last Post: 15-06-2012, 12:21 PM -
Supported rail or other?
By lateAtNight in forum Rails, Guideways & BearingsReplies: 16Last Post: 14-11-2008, 02:28 PM
