Thread: Advice: Timing Pulleys and Belts
With 5M HTD pulleys the maximum you can use is 28T (48mm flange diameter). It's generally not important to have high speed on the Z-axis, so I would recommend around 1:1 ratio.
You can work out the belt length using this:
http://www.sdp-si.com/cd/default.htm
Ballscrews - pulleys - timing belts
By vre in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 15-01-2014, 08:03 PM -
Belts & pulleys,
By jcb121 in forum Belt Drive, Pulleys & TimingReplies: 4Last Post: 29-09-2012, 12:32 AM -
pulleys and belts - sizes
By mocha in forum Belt Drive, Pulleys & TimingReplies: 3Last Post: 22-07-2012, 05:16 PM -
Belts & pulleys & advice please
By CNCBlug in forum Belt Drive, Pulleys & TimingReplies: 12Last Post: 29-04-2012, 10:31 PM -
Source for XL timing belts and pulleys
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 20-08-2009, 01:21 PM
