23-06-2012 #4
i cut mostly plastics on my machine (acetal/delrin) some abs type plastics
and some alluminium
my machine is a small heavy built router (500mm x 400mm ish)
if you have the time it makes sense to build your own machine and spindles... (if not, look for a small machine with ballscrews and profile rails all round)
there are enough people on this forum to help you through the pitfalls of building your own machine... its not rocket science, if you have the will power you will manage it
it will cost you a fraction of the cost and will be made to fit your spec (and you will know how to fix it when it breaks)
you could browse the build logs and copy someone elses machine, im sure most would give you any drawings they have and talk you through the hardships of that perticular design
designs based on aluminium extrusions are reasonably simple to build and dont require much fancy footwork :)
Seeking some practical squaring advice.
By Wal in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 09-01-2014, 12:04 AM -
NEW MEMBER: Seeking advice on a CNC setup for (one off) machining carbon fiber plate
By Tomcat in forum New Member IntroductionsReplies: 0Last Post: 03-03-2013, 01:43 PM -
NEW MEMBER: New member seeking advice
By Rob Wol in forum New Member IntroductionsReplies: 14Last Post: 02-02-2012, 10:54 PM -
Much advice needed for an 8' x 4' cnc router project / and vacuum table
By FlightCaseCo in forum General DiscussionReplies: 1Last Post: 01-01-2012, 12:34 AM -
Wiring Project
By Karl in forum Electronic Project BuildingReplies: 2Last Post: 07-07-2011, 02:11 PM
