Thread: M542 Driver
27-06-2012 #23
Right then have new components arrive today, the circuit will not power up without it and problem now is which way round should it go?
if i was to just bridge it it would be closed circuit. I'm now thinking the diode is part of clamping circuit maybe? if this was the case then the negative side of the diode would need to go to the negative side of circuit?
It does not make sense to just have a diode across the power lines as a protection circuit right? am i missing something here? wish i had a circuit diagram. The board won't clean up enough for me to see the tracks either
M542 driver - motor vibration at low speeds
By birchy in forum Motor Drivers & ControllersReplies: 34Last Post: 22-11-2013, 08:16 PM -
GX16 to M542
By Carlb1058 in forum Stepper & Servo MotorsReplies: 3Last Post: 29-07-2013, 11:08 PM -
M542 driver (Zapp) half or full current?
By Smiler in forum Stepper & Servo MotorsReplies: 9Last Post: 09-07-2013, 09:02 PM -
M542 wiring
By manofgresley in forum Motor Drivers & ControllersReplies: 4Last Post: 03-09-2012, 08:52 AM -
ZP5A-INT breakout an M542 driver problems
By ciaranconlon in forum Motor Drivers & ControllersReplies: 2Last Post: 09-04-2012, 05:52 PM
