Thread: M542 Driver
28-06-2012 #26
Glad you fixed it - one day I'll get round to fixing the two broken M752's I have. Not had chance to look at them but I suspect some of the MOSFETs would need replacing.
Bit off topic but...
They're cutting it fine with the MOSFET ratings - both of our M542s use MOSFETs only rated for 55V absolute maximum. Considering they're driving an inductive load and the manual states they can be used on up to 50V I'm surprised the voltage spikes on switching do not exceed 55V. The M752 (75V) and 2m880N (70V) have a much more realistic safety margin as they both use IRF540 MOSFETs which are rated for 100V. I therefore run my M752 drivers on the rated 75V having also checked with oscilloscope that the voltage spikes do not exceed 100V.
Ahh so it was a transient voltage suppression diode...I don't see why you would need to consider scraping the mask away to test.
Yep, except the diode in question is across the supply not the individual MOSFETs in the H-bridges, however the principle is the same. I think the difference here is all the energy is immediately dumped into the junction of the diode, not necessarily going round and round. That diode should protect it against unplugging the power when running, but please don't try it!
M542 driver - motor vibration at low speeds
By birchy in forum Motor Drivers & ControllersReplies: 34Last Post: 22-11-2013, 08:16 PM -
GX16 to M542
By Carlb1058 in forum Stepper & Servo MotorsReplies: 3Last Post: 29-07-2013, 11:08 PM -
M542 driver (Zapp) half or full current?
By Smiler in forum Stepper & Servo MotorsReplies: 9Last Post: 09-07-2013, 09:02 PM -
M542 wiring
By manofgresley in forum Motor Drivers & ControllersReplies: 4Last Post: 03-09-2012, 08:52 AM -
ZP5A-INT breakout an M542 driver problems
By ciaranconlon in forum Motor Drivers & ControllersReplies: 2Last Post: 09-04-2012, 05:52 PM
