Thread: Switch for motor?
Hi guys,
I have recently bought a tapping machine with a 3 phase motor. I have changed the motor to single phase. The spec of the motor is as follows:
50hz
0.18kw
220-240v
1.5A
I need to buy a green and red push bottom switch to attach to the machine but have no idea of the technical name for it? Any ideas? A link to website would be appreciated too.
Thanks guys.
26-06-2012 #2
It's a "motor starter", ebay is full of them but you need to disallow "starter motor" when you search
26-06-2012 #3
Or search for a 'DOL' as they are also known as
27-06-2012 #4
If the motor is only 0.18KW then you dont actually need a starter. Control gear is only required for motors with ratings above 0.37KW if I remember correctly.
27-06-2012 #5
You don't need a starter switch for such a small motor but it is a good idea to use a "no volt release" or NVR switch so that the motor won't restart after a power cut.
For example this
Russell.
Proximity switch NPN or PNP
By Matt81 in forum General ElectronicsReplies: 9Last Post: 19-04-2014, 11:38 AM -
Limit switch issues?!?
By jonbabbz in forum General ElectronicsReplies: 10Last Post: 06-02-2014, 07:37 PM -
Help withController dip switch settings and Mach3 motor tuning
By liamo1991 in forum Motor Drivers & ControllersReplies: 2Last Post: 15-11-2013, 02:22 AM -
Limit switch Cable ...
By Wobblybootie in forum General ElectronicsReplies: 3Last Post: 17-01-2011, 04:37 PM -
Limit switch's - best configuration?
By HiltonSteve in forum General ElectronicsReplies: 16Last Post: 13-08-2009, 01:26 PM
