Thread: Ambitious newby
    Lives in East Lothian, United Kingdom. Last Activity: 4 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    A basic diesel engine will inject a good bit before TDC. Diesel is quite slow to ignite, so to get peak power and good air/fuel mixing, the fuel has to be ignited long before TDC (IIRC at typical slow idle it's about 18deg BTDC). This is why diesels knock so much, as the engine is pretty much on the verge of stalling at TDC due to the high pressure.
    With modern common rail systems, fuel injection is now a multi-stage process. As the piston approaches TDC, a small amount of fuel is pre-injected, which results in an intial flame, then as TDC is approached main injection occurs as a further series of injections, which ignite quicker due to the already burning fuel.
    As for diesel 2strokes, they have existed in the past. Some had conventional valve trains, some were ported, but pretty much all of them were supercharged.
    Diesel 2-strokes used to be used extensively for model aircraft without supercharging before the days of outrunner electric motors. I'm not sure how well they scale up though.
    Russell
    Quote Originally Posted by russell View Post
    Diesel 2-strokes used to be used extensively for model aircraft without supercharging before the days of outrunner electric motors. I'm not sure how well they scale up though. Russell
    I think they ran on nitro, but maybe this one runs on nitro.
    We used to make our own fuel. A mixture of paraffin, castor oil, and ether with a tiny amount of amyl nitrate if more power was needed.
    Russell.
    I wasn't talking about model engines. I was talking about ones that could power real vehicles!
  1. Newby needs help
    By Gregor in forum Tool & Tooling Technology
    Last Post: 07-01-2014, 03:33 AM
  2. RFQ: Ambitious Bicycle build project needs help
    By Psycholist666 in forum Projects, Jobs & Requests
    Last Post: 16-03-2013, 12:10 AM
  3. NEW MEMBER: Newby from London, Canada
    By Leadfootin in forum New Member Introductions
    Last Post: 25-12-2010, 01:11 PM
  4. NEW MEMBER: Newby Introduction
    By Sides in forum New Member Introductions
    Last Post: 06-09-2010, 10:47 PM
  5. NEW MEMBER: Birmingham, newby.
    By Malc in Brum in forum New Member Introductions
    Last Post: 23-11-2008, 06:28 PM
