Thread: Ambitious newby
You need to consider power delivery. Each time a cyclinder fires, you get a high load followed by a power surge. This causes the crankshaft to deform, so it's got to be suitably designed to handle the peak torque. By having two cylinders firing at the same time, you'll be putting a lot more stress through the crankshaft.
Ideally you want power delivery at equal intervals, which would mean the two crank pins being 90degrees apart, however you'd have to take into consideration the crankshaft balance.
Newby needs help
By Gregor in forum Tool & Tooling TechnologyReplies: 1Last Post: 07-01-2014, 03:33 AM -
RFQ: Ambitious Bicycle build project needs help
By Psycholist666 in forum Projects, Jobs & RequestsReplies: 4Last Post: 16-03-2013, 12:10 AM -
NEW MEMBER: Newby from London, Canada
By Leadfootin in forum New Member IntroductionsReplies: 1Last Post: 25-12-2010, 01:11 PM -
NEW MEMBER: Newby Introduction
By Sides in forum New Member IntroductionsReplies: 3Last Post: 06-09-2010, 10:47 PM -
NEW MEMBER: Birmingham, newby.
By Malc in Brum in forum New Member IntroductionsReplies: 1Last Post: 23-11-2008, 06:28 PM
