Thread: Air cooling/SWARF removal
29-06-2012 #3
The cooling due to the air flow from sucking up the swarf will be negligible. I've found the compressed air method to be effective at clearing the swarf when milling Nylon (which is not the plastic you're cutting if I recall correctly), but didn't actually notice any change in the finish since with a single flute tool there's plenty of room for the swarf anyway.
Bear in mind the duty cycle rating on the air compressor you get as you will want to run it continuously, otherwise you will overheat and ultimately break it. Expect to buy a compressor rated for a much higher power / capacity to compensate for having to run it continuously.
Here:
http://www.arceurotrade.co.uk/catalo...px?search=hose
Or:
http://www.ebay.co.uk/sch/Business-O...0hose)&_sop=15
RFQ: Shot blasting or other paint removal
By craigrobbo in forum Projects, Jobs & RequestsReplies: 14Last Post: 01-02-2013, 12:21 AM -
AM882,s and Mach3 ......plus hair removal !!!
By Buba b in forum Motor Drivers & ControllersReplies: 3Last Post: 26-10-2012, 05:11 PM -
i7 Water cooling system
By Jonathan in forum Metalwork Project ShowcaseReplies: 19Last Post: 01-01-2012, 06:27 PM -
Spindle cooling pump
By p1lts in forum General DiscussionReplies: 3Last Post: 04-11-2011, 01:58 PM -
Looking for Vacuum/Swarf extraction tubing
By m.marino in forum Machine DiscussionReplies: 2Last Post: 18-08-2009, 12:35 AM
