    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    Micheal, I'd go for a combination of both. Small jet aimed at the cutter to keep things cool, and a vac to try and control the swarf.
    The main thing I suspect you need to aim for is to get the swarf away from the cutting area, so the cutter isn't re-cutting swarf and clogging itself.
    And I know how you feel. I thought I had finaly got some time to catch up with a few of my own projects, however the paying job list has just grown :-/
    (if anybody can magically weld a crankshaft back together without dismantling anything, there's a tractor sitting outside with said problem...)
    Tenson, the brand name stuff is Loc-Line, however there are a good few cheaper versions around. The last stuff I got was from Arc Euro Trade, but most engineering type suppliers have it in some form.
    Micheal I'm with M_C on this.! Keep the air to a minimum other wise you'll need a large CFM compressor and tank. Low direct pressure is all thats needed to clear the chips enough to stop re-cutting then good vacuum will do the rest.
    Re cooling the spindle (which is what I think you mean when you say "indirect cooling") then I'd forget the compessed air route has the volume required would be large, the electricty alone of running a big compressor would pay for a water cooled spindle given time.!!
    Maybe design some outer rap-around water cooled jacket type affair.??? Bit like an hot water bottle in reverse. .
  1. RFQ: Shot blasting or other paint removal
    By craigrobbo in forum Projects, Jobs & Requests
    Last Post: 01-02-2013, 12:21 AM
  2. AM882,s and Mach3 ......plus hair removal !!!
    By Buba b in forum Motor Drivers & Controllers
    Last Post: 26-10-2012, 05:11 PM
  3. i7 Water cooling system
    By Jonathan in forum Metalwork Project Showcase
    Last Post: 01-01-2012, 06:27 PM
  4. Spindle cooling pump
    By p1lts in forum General Discussion
    Last Post: 04-11-2011, 01:58 PM
  5. Looking for Vacuum/Swarf extraction tubing
    By m.marino in forum Machine Discussion
    Last Post: 18-08-2009, 12:35 AM
