Thread: Air cooling/SWARF removal
Micheal I'm with M_C on this.! Keep the air to a minimum other wise you'll need a large CFM compressor and tank. Low direct pressure is all thats needed to clear the chips enough to stop re-cutting then good vacuum will do the rest.
Re cooling the spindle (which is what I think you mean when you say "indirect cooling") then I'd forget the compessed air route has the volume required would be large, the electricty alone of running a big compressor would pay for a water cooled spindle given time.!!
Maybe design some outer rap-around water cooled jacket type affair.??? Bit like an hot water bottle in reverse. .
RFQ: Shot blasting or other paint removal
By craigrobbo in forum Projects, Jobs & RequestsReplies: 14Last Post: 01-02-2013, 12:21 AM -
AM882,s and Mach3 ......plus hair removal !!!
By Buba b in forum Motor Drivers & ControllersReplies: 3Last Post: 26-10-2012, 05:11 PM -
i7 Water cooling system
By Jonathan in forum Metalwork Project ShowcaseReplies: 19Last Post: 01-01-2012, 06:27 PM -
Spindle cooling pump
By p1lts in forum General DiscussionReplies: 3Last Post: 04-11-2011, 01:58 PM -
Looking for Vacuum/Swarf extraction tubing
By m.marino in forum Machine DiscussionReplies: 2Last Post: 18-08-2009, 12:35 AM
