    Quote Originally Posted by m.marino View Post
    So Looking at either a 24 liter tank and low pressure
    That's what I tried with my cheap 24L compressor from a car boot sale...with the minimum flow rate for it to be useful I still could not run it continuously. However if your part doesn't take too long (hard to say how long) to cut then that may not be a problem.
    decreasing the amount of hard angles is a good thing with vacuum
    Good thing with either really... most important is to use as big conduit/tube as you can.
    Lives in East Lothian, United Kingdom. Last Activity: 14 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Okay,
    So Looking at either a 24 liter tank and low pressure with an outside storage unit for the compress next to the shop or looking on ebay for a used hydrovane (lots of luck on that one) in good condition (need even better luck on that) and getting a brace in the roof to put a track on so the hoses can follow (decreasing the amount of hard angles is a good thing with vacuum).
    I've got a 25litre compressor in somebody elses garage if you want to try that option. I think it's only a 1.5 or 2 hp though. I bought it several years ago just to get a job done, somebody borrowed it as a temporary solution and it's sat gathering dust since. You can have it for a minimal fee.
    I've got a couple engine driven hydrovane compressors needing collected. They're likely of 80's/early 90's vintage, but will of seen little work. I just want the engines, so you're welcome to the compressors if they're any use.
    It's all in the nozzle size.
    Not for something carrying solids/fluids you don't!
    You need to keep the air speed up, or it'll drop the solids and clog!
    Ok, clearly I was generalising too much as obviously it has to be a balance between the two. This site explains a lot:
    http://billpentz.com/woodworking/cyc...fm#DuctingSize
  1. RFQ: Shot blasting or other paint removal
    By craigrobbo in forum Projects, Jobs & Requests
    Last Post: 01-02-2013, 12:21 AM
  2. AM882,s and Mach3 ......plus hair removal !!!
    By Buba b in forum Motor Drivers & Controllers
    Last Post: 26-10-2012, 05:11 PM
  3. i7 Water cooling system
    By Jonathan in forum Metalwork Project Showcase
    Last Post: 01-01-2012, 06:27 PM
  4. Spindle cooling pump
    By p1lts in forum General Discussion
    Last Post: 04-11-2011, 01:58 PM
  5. Looking for Vacuum/Swarf extraction tubing
    By m.marino in forum Machine Discussion
    Last Post: 18-08-2009, 12:35 AM
