Thread: Air cooling/SWARF removal
30-06-2012 #12
Unfortunately those two statements don't really belong together. The flow rate from a standard household vacuum cleaner is very low compared to even a small proper dust extractor - roughly 10 times less. I tried a couple of vacuum cleaners and they were completely useless as the tool threw the the chips out at such a high speed that the vacuum could not catch them. The only way to get it to work was to add a shroud to intercept the chips, giving them time to be caught. Still it's not a good solution, so I got one of these, which was cheaper at the time:
http://compare.ebay.co.uk/like/18042...bar&adtype=pla
I was intending to make a cyclone for it, but since I almost exclusively cut aluminium it only really gets used when I surface the MDF bed it's hardly worth it. I leave it to surface the bed on it's own as I don't trust it to filter the fine MDF dust properly.
RFQ: Shot blasting or other paint removal
By craigrobbo in forum Projects, Jobs & RequestsReplies: 14Last Post: 01-02-2013, 12:21 AM -
AM882,s and Mach3 ......plus hair removal !!!
By Buba b in forum Motor Drivers & ControllersReplies: 3Last Post: 26-10-2012, 05:11 PM -
i7 Water cooling system
By Jonathan in forum Metalwork Project ShowcaseReplies: 19Last Post: 01-01-2012, 06:27 PM -
Spindle cooling pump
By p1lts in forum General DiscussionReplies: 3Last Post: 04-11-2011, 01:58 PM -
Looking for Vacuum/Swarf extraction tubing
By m.marino in forum Machine DiscussionReplies: 2Last Post: 18-08-2009, 12:35 AM
