10-06-2013 #1
I just bought an enclosure, cnc / liquid gasket printer, for the desktop Isel Techno FB2 that was inside.
so I am offering all the bits that I don't require, but I do want new motors and controllers, mach3/4 and that, anyways here goes
here is what I bought, took two goes in my little estate car, Fulham London to Stafford, but at least now it is all in bits
the long side are 90 by 45 = 1450mm
there are six bits
the short sides are 1080mm
there are 6 bits of this - maybe 8
the legs are 90mm by 90mm and have bolt in feet
there are 4 complete blue panels, for all 4 sides
the buttons on the front could be for auto stop
if you left it as it is, max width is 1080 plu 90 plus 90 = 1260mm, 4ftand a smidgers
the long then is 1450 plus 90 - leaving the tall legs = 1540mm, 1525 is 5ft
theer are 2 bits of 90 by 45 to make the y axis with, i think another few lengths to make a shelf on the tall legs, and the z axis
there are 2 3/4'' 19mm solid alloy plates to make the gantry ends, there are another two bits of 15mm or 19mm to make the z axis
there are 4 four foot flat sliders with bosch bearings, enough to then do the y axis and loads to make a very rigid z axis.
these are fitted to 4 bits of 60 by 45mm -
THERE ARE ALSO A PAIR OF IAR RAMS AND 2 PUMPS AND LOTS OF PNEUMATIC CONTROLLING STUFF - I DON'T KNOW WHAT IT DOES THOUGH.
there are two of those alloy thick plates with a nice hole in the centre for you to cut a pair of welly boots from, and have the nice radius
also there is stack and stacks of 45mm box, lots of nuts and bolts
all the wireing is there to the controllers about 1998 from what I can see, I can take a pic.
there are 2 old wee amc 3 axis controllers, , two hand held doofers, all the wireing and connectors
two of these
and two of these, the other one is a bit bigger all full of giblets
have all the wireing and connectors too.
there are two BUSHE pumps, rams, connectors and valves
location magnet things for 3 axis, 3 on each,
also have a trend t10 1/2 inch collet 2000kw plunge router, used for about 2 hours - ten years ago, in the case.
also have a 100a invertor / tig welder plasma cutter
i really should nail together a 4foot by 2 foot plasma table........
all used
IT IS ALL APART, YOU CAN GET IT IN AN ESTATE CAR
I AM WILLING TO POST EVERYTHING - BAR THE BLUE SIDES AT COST.
NOW THE BEST BIT i NEED
Nema23 Stepper Motor Kit 3.1Nm x 3 Axis
ALSO NEED A SPINDLE AND MOUNT
AND SOME MACH3 - OR 4
OH AND A USB/lan BOB
SO HAPPY TO HAVE A SWAPSIES.
THANKSLast edited by nobby; 10-06-2013 at 10:16 PM.
13-06-2013 #2
erm, controlling stuff sold
NOW REQUIRE A SPINDLE AND MOUNT.
A USB BREAK OUT BOARD
HAVE NEW MOTORS
FOR SALE 2 ROUND NEMA 23'S 8 WIRE, AND A 6 WIRE SUARE ONE
ALSO 3 1/4 -TO - 1/4'' CONNECTORS
NEED SPINDLE AND MOUNT AND SOFTWARE.
COME ON!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
STEVE
0774 858 2044
LOADS OF 40MM BOX
YOU COULD MAKE A HALFF DOXEN TABLE YOPS
14-06-2013 #3
TWO
metal work cnomo air rams/ type 1133 bore 32mm stroke 600mm
FOUR
bosch pop up solenoids
TWO
bushe pumps, I think the otehr one is thesame, its in the garage away from the house.
will exchange for
ONE - 2.2kw spindle and invertor, with the 80mm mount - ebay
pics of isel Techno FB2 motors, a PAIR in good order £100
eight wire
ONE
six wire sanyo nema style 23, with 1/4'' out 76mm long
£25
this macjhine was a twin feed pneumatic track that locked, so as tyo have a mobile phone gasket printed onto it
the tacks do not come with the pneumatics, but they are for sale
you could bolt it all back together, It was 'JUST' too heavy for me to manage, plus I had to get it out of the main machine
STOP PRESS
4' by 5' table £500, comes with metal sides and twin side railsLast edited by nobby; 14-06-2013 at 04:03 PM.
25-06-2013 #4
pneumatics sold
controllers sold
odd rails sold
just the 5 by 4 table with sides left.
oh and a few lengths of 45 by 45Last edited by nobby; 27-06-2013 at 05:34 PM.
SWAP: 2 onld controllers, 5 by 4 modular table, 4 - 4ft sliders, 2 air rams, 2 pimps, etc
By nobby in forum Items For SwapReplies: 2Last Post: 29-05-2014, 11:33 PM -
Effect of Forces on Gantry Cross-Sections?
By WandrinAndy in forum Gantry/Router Machines & BuildingReplies: 37Last Post: 22-12-2012, 10:34 PM -
Straight sections of box steel
By gavztheouch in forum Metalwork DiscussionReplies: 2Last Post: 03-01-2012, 02:37 PM -
FOR SALE: Lots of Bosch Rexroth Aluminium extrusion 50mm x 50mm.
By michael in forum Items For SaleReplies: 12Last Post: 12-10-2011, 08:52 AM -
FOR SALE: Z slides ??
By John S in forum Items For SaleReplies: 4Last Post: 27-09-2009, 11:03 PM
