Thread: Raspberry Pi
31-07-2012 #21
Thanks.
Been playing around with interpolation routines but run into a snag... so need to go back and rethink the code I've written. Issue is this... in 2D to make it easy... want to move from 0,0 to 1000,1300 say (steps, not mm). Lets assume that the feed rate requires this to take 1 second... then the x rate is 1000steps/sec and the y rate is 1300 steps/sec. But I have a base rate of 5000 steps sec (10khz interrupt/2). so X is every 5th interrupt and y is every 3.85 interrupts.. but you cant do 3.85.. so i need a much higher interrupt rate and some interpolation... in this case 50000 and divisors of 38,38,39,38,38,39,38,38,38,39 per 5000 gives 1301 with a max error of 2 steps... So i need to get that kernel level interrupt working... in the meantime, i'll have to run it all at 1/10 speed :(
cnc print a raspberry
By george uk in forum General DiscussionReplies: 7Last Post: 13-06-2014, 01:13 PM -
Raspberry Pi as a PC + Mach3 .. very possible
By Fivetide in forum General ElectronicsReplies: 2Last Post: 05-09-2012, 11:18 PM
