Thread: Raspberry Pi
01-08-2012 #25
It is fun isn't it, the hours I spent making it work. Everytime I thought I had it figured I found the next little snag
I find the major axis which steps on every interrupt, and slave everything else to that. I reload the timer after every step from the acceleration table, stretching the delay by 1.5 (approx root 2) if both X and Y go together.
I can give you the working code that drives my mills but it may not help being written in Z80 assembler. It runs from a pre-digested buffer of straight lines without any multiplies or divides. On a slow CPU, 8MHz, the interrupt steps anyone set to step on entry then reconfigures the step and direction lines at exit.
I'm a bit of a dinosaur.
cnc print a raspberry
By george uk in forum General DiscussionReplies: 7Last Post: 13-06-2014, 01:13 PM -
Raspberry Pi as a PC + Mach3 .. very possible
By Fivetide in forum General ElectronicsReplies: 2Last Post: 05-09-2012, 11:18 PM
