Thread: Raspberry Pi
01-08-2012 #26
No, but with 1 step = 0.05mm, a few steps out is problematic. I'm running at 10KHz interrupts now but there are reports of others handling 100KHz interrupts, using the PRE_EMPT flags in the kernel compile (another reason to re-compile). The only speed limit I have right now is the fact that the interrupt handler runs in user space so context switching is a significant part of the interrupt latency (about 50uS measured).
Thats essentially the way I am doing it. I have a buffer of 1024 'moves' but if I have to fill it with 1 step moves its going to need to be much bigger or the steppers are going to run out of work to do... Or did you convert the whole of the G-code into steps before putting it in the buffer? How big is your buffer?
How fast is your interrupt and do you change the rate? It occured to me that one way to control feed rate would be to have a programmable interrupt timer using the Pi's PWM generator - but that wastes a GPIO output pin as I don't think you can programme it to interrupt if its not allocated to an output pin (and possibly needs to be fed back to an input).
cnc print a raspberry
By george uk in forum General DiscussionReplies: 7Last Post: 13-06-2014, 01:13 PM -
Raspberry Pi as a PC + Mach3 .. very possible
By Fivetide in forum General ElectronicsReplies: 2Last Post: 05-09-2012, 11:18 PM
