Thread: Raspberry Pi
01-08-2012 #27
I have a buffer of straight lines. Lines currently are 24 bits long max. With the acceleration/deceleration/directions included I can define a straight line, XYZ, in 12 bytes.
I pinched the idea, I won't say where from. It also makes jogging easy but the buffer needs canny attention after you hit pause because unexpected braking has to become unexpected acceleration when you unpause.
I put a tidemark at 800 lines, if the buffer drops below that it gets another 10 lines. Drip feeding from the host may not be the way you want to go.
I use 2 interrupts, one for the stepping, one for the comms.
I have one bug at the mo', if the host misses a byte from the status report it waits forever for it to arrive. I need to add a timeout/retry. I haven't lost any data going the other way, yet, touch wood.
Edit: You step at .05mm? Is that a typo? I step at .005mm.Last edited by Robin Hewitt; 01-08-2012 at 12:24 PM.
cnc print a raspberry
By george uk in forum General DiscussionReplies: 7Last Post: 13-06-2014, 01:13 PM -
Raspberry Pi as a PC + Mach3 .. very possible
By Fivetide in forum General ElectronicsReplies: 2Last Post: 05-09-2012, 11:18 PM
