Sounds promising, I'd probably only need to lengthen the ends a bit, maybe deepen the circlip groove a tadge. A couple of flat spots would be handy.
Can I find the dimensions and details for the double nuts on your website? They seem to be hidden under pre-machined screws, so when you click for info you get told about end machining rather than nuts :confused:
Last time I bought a "zero backlash nut" it was from that other bunch. Turned out I had to crush it sideways. A bit tricky when it's buried under a milling table
17-12-2008 #2
THe link to the double ball nuts is here
http://www.slidesandballscrews.com/pdf/35-36.pdf
the ball nuts i have in stock are pre loaded to give a max backlash of 20 micron.
If you want a zero backlash nut, this will need to matched to the ball screw at the factory.
Visit Us: www.automationshop.co.uk
17-12-2008 #3Visit Us: www.automationshop.co.uk
Congratulations to Gary @ Zapp
By JAZZCNC in forum General DiscussionReplies: 7Last Post: 21-09-2013, 07:44 PM -
Zapp 3-Axis kit - putting it all together
By birchy in forum Motor Drivers & ControllersReplies: 5Last Post: 18-02-2013, 12:05 PM -
10% Discount weekend At Zapp Automation
By Gary in forum Marketplace DiscussionReplies: 10Last Post: 19-02-2012, 12:42 PM -
ZAPP SY60 wiring help
By Smiler in forum Stepper & Servo MotorsReplies: 7Last Post: 07-06-2010, 08:28 PM -
HELP Gary, I'm having a disaster
By Robin Hewitt in forum Linear & Rotary MotionReplies: 3Last Post: 16-04-2009, 10:07 AM
