If your drill is sharp enough you need relatively little torque to drill, much of the time the spindle will do most of it under its own weight...
Its all to do with cutting speed, feed rates and chip sizes...
Basically to drill a 6mm dia hole in Ali, needs a drill speed of 5000rpm and a feed rate of about 10mm/min (all nominal values, taken from one of the many online feed/speed calculators)
The force needed to push the drill through the material is roughly 6N, and the cutting power about 10W. (yes its theoretical, Jazz)
That 6N of force needs 5mN of torque on a 5mm screw or 10mN on a 10mm screw... it generally makes little difference so other parameters, such as cost, apply...
Though these are theoretical numbers, even if they are an order of magnitude out from reality, it still makes no difference. The main job of the ballscrew in the Z axis is to support the weight of the spindle, not to make a vertical cut...
The Following User Says Thank You to irving2008 For This Useful Post:
17-08-2012 #2
Not getting into this other than to say my 2.2KW (2200W) WC spindle is rubbish for drilling above 6mm in Aluminium.? WHY . . because where talking about very different things really.!!
When it comes to actual "real" cutting then torque very much does matter but that's not to be confused with pushing force but torque the spindle produces.
So Irving your correct regards pushing figures not being too important but the F/S aren't really practicle in "real" terms because no one would want to drill aluminium @10mm/min.? G-wizzard actually gives 2900rpm and 200mm/min has a conservative feed rate.? . . . . I actually drill aluminium @ 4500rpm and peck drill @ 600mm/min so big difference's here compared to 10mm/min @ 5K rpm.?
tools for 3d wood carving
By chris in forum Marketplace DiscussionReplies: 5Last Post: 18-01-2014, 04:23 AM -
BUILD LOG: Monster fixed gantry router for aluminium & wood
By jonboycnc in forum DIY Router Build LogsReplies: 9Last Post: 12-01-2014, 11:26 PM -
BUILD LOG: Aluminium Extrusion CNC Router Build
By joshendy in forum DIY Router Build LogsReplies: 9Last Post: 10-04-2012, 08:26 PM -
BUILD LOG: Planning and build of my "8020" aluminium CNC Router
By monza in forum DIY Router Build LogsReplies: 14Last Post: 06-02-2010, 11:55 PM -
Source of Wood to build a Solsylva 37x25 CNC
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 06-07-2009, 11:42 PM
