12-07-2012 #2
I'm finding far too many variables floating around in my grey-matter, causing me to go off at tangents researching multiple different options of anything and everything, so am taking some decisions to lessen the load on my limited mental capacity.
Have decided on the adjustable bed type design similar to Iwant1's, but will do the initial build on a flat aluminium frame in the caravan, and only weld up the steel frame when I eventually get it into a workshop before using it in anger.
As I don't have machining facilities in said caravan, have bought a set of pre-machined ballscrews from linearmotionbearings2008 for about £330+duty:
- 4pcs anti backlash ballscrews
- RM1605-300/850/1150/1150mm-C7 (4 screws+4 balnuts+4endmachinings)
- 4 sets BK/BF12 with locknut and circlip
- 4pcs of 6.35mm*10mm flexible couplings
Have also roughly decided on using the following, but will only buy these later:
- SBR20 supported rails and SBR20UU blocks for all three Axes
- PM752 drivers x 4
- 3Nm NEMA23 steppers x 4 (SY60STH88-3008B ?)
- Mach3
- Ethernet SmoothStepper
Meantime, I will work on the rough design in SketchUp, thanks to the help from the forum, and only determine exact dimensions when the ballscrews arrive.
Btw, many thanks to JAZZCNC for giving me plenty of time and great info!
tools for 3d wood carving
By chris in forum Marketplace DiscussionReplies: 5Last Post: 18-01-2014, 04:23 AM -
BUILD LOG: Monster fixed gantry router for aluminium & wood
By jonboycnc in forum DIY Router Build LogsReplies: 9Last Post: 12-01-2014, 11:26 PM -
BUILD LOG: Aluminium Extrusion CNC Router Build
By joshendy in forum DIY Router Build LogsReplies: 9Last Post: 10-04-2012, 08:26 PM -
BUILD LOG: Planning and build of my "8020" aluminium CNC Router
By monza in forum DIY Router Build LogsReplies: 14Last Post: 06-02-2010, 11:55 PM -
Source of Wood to build a Solsylva 37x25 CNC
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 06-07-2009, 11:42 PM
