    Quote Originally Posted by WandrinAndy View Post
    Please "holler" about the problems... I'm that thickskinned that I cannot recall ever having taken offence at anything!
    Thanks,
    PS. Is 5mm aluminium sufficiently thick to make a M6/M8 tapped thread reasonably strong?
    Ok I'll holler first but not too much. . Lol
    45x45 extrusion is pretty weak so I would consider going larger.!
    5mm in aluminium is NOT enough. M6 = 1mm pitch so only 4 full threads M8= 1.25mm pitch so 3 full threads no where near enough and it will strip.!!
    Thanks Jazz.
    I had thought that the heavy version of the 45x45 would be strong enough as it is bolted along the back of it's whole length to 9.5 plate. I will look at replacing the top section with 45x90 then. Do you think this will be enough?
    I'm hoping that tapping into 9.5mm plate... 90% more threads.... is just ok then?
    Nah even the heavy version isn't has strong as you think.!! The 45x90 will be better but I'd put it top & bottom and have the wide bit flat.
    This way it ties into the sides better and gives more resistance to bending in lateral cutting directions.! It doesn't Add much to the vertical up & down strength plunging will inflict but the 10mm plate will help here and plunging should be avoided if at all possible anyway.! Most of the time the machines cutting and the forces are lateral.!!
    10mm is just about ok for threading in Alu.
    I would have thought that my design as pictured already provides lateral resistance roughly equivalent to what you're suggesting, as a cross-section of the bottom of the gantry consists of 45x45 bolted close to the backwards pointing 51mm leg of the 9.5 angle? And the 9.5 angle extrusion is bolted to both the base and the uprights of the X-carriage hopefully creating a very rigid joint?
    OK then go for it.!
  1. tools for 3d wood carving
    By chris in forum Marketplace Discussion
    Last Post: 18-01-2014, 04:23 AM
  2. BUILD LOG: Monster fixed gantry router for aluminium & wood
    By jonboycnc in forum DIY Router Build Logs
    Last Post: 12-01-2014, 11:26 PM
  3. BUILD LOG: Aluminium Extrusion CNC Router Build
    By joshendy in forum DIY Router Build Logs
    Last Post: 10-04-2012, 08:26 PM
  4. BUILD LOG: Planning and build of my "8020" aluminium CNC Router
    By monza in forum DIY Router Build Logs
    Last Post: 06-02-2010, 11:55 PM
  5. Source of Wood to build a Solsylva 37x25 CNC
    Last Post: 06-07-2009, 11:42 PM
