17-08-2012 #23
Thanks Jazz.... that's exactly what was befuddling me... That whilst I was pretty sure that you recommended 1610.... your machine uses 1605... Because it was in the early days of your evolution... Lol.
I didn't actually think that 1610 gave better torque than 1605... thought it was 'tother way around, but it has now finally sunk in! I just hope it doesn't drop out the other side....
That makes total sense.... I will make use of a service that beltingonline offer at a small-ish fee... they machine grubscrew holes... one/two off different sizes. Have just had a mosey at their website and the options available vary depending on pulley size... only M2-M3 for the smallest 12T pulley, M2-M6 for a 20T pulley, and M2-M10 for a 40T pulley. Their website also states that "Position of grub screws will be in hub as standard".... the hubs are only 5.5mm long so reckon that they put two opposite each other.
So.... I will use 1610 1:1 using 20T [o.d=36mm] pulleys with 2 off M6 grubscrew holes in each... and only look at other gearing ratios in the future if it seems necessary for specific tasks.
PS. I think Jonathan had mentioned I might as well use 1605 on the much shorter Z-axis for better resolution.... Is this because torque isn't really needed on this Axis... Unless drilling I suppose?
Thanks again,
AndyLast edited by WandrinAndy; 17-08-2012 at 03:58 PM.
tools for 3d wood carving
By chris in forum Marketplace DiscussionReplies: 5Last Post: 18-01-2014, 04:23 AM -
BUILD LOG: Monster fixed gantry router for aluminium & wood
By jonboycnc in forum DIY Router Build LogsReplies: 9Last Post: 12-01-2014, 11:26 PM -
BUILD LOG: Aluminium Extrusion CNC Router Build
By joshendy in forum DIY Router Build LogsReplies: 9Last Post: 10-04-2012, 08:26 PM -
BUILD LOG: Planning and build of my "8020" aluminium CNC Router
By monza in forum DIY Router Build LogsReplies: 14Last Post: 06-02-2010, 11:55 PM -
Source of Wood to build a Solsylva 37x25 CNC
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 06-07-2009, 11:42 PM
