12-07-2012 #11
That's because you only spent 'today' looking, you have to be patient to get the good deals - bidding not buyitnow. Yes I know, I used to think it's annoying when people say things like that, but it's worked for me in the end.
If you can blow the carriage along, or it drops if you hold the rail vertically, then the pre-load is zero (Z0). When there is preload there is no clearence (play) between the rail and carriages, in fact the clearance is negative so it's an interference. This means that when the carriage is slid on to the rail the bearings distort slightly, so there is a force between the bearings and the rail - hence the name preload.
I'd consider having zero, or very low, pre-load a much bigger issue than only two rows of balls. You've got both...
P.S. Noticed there's two discussions going on here, the machine and sketchup - I can separate them if you want?
CONVERSION: Re-Built a used CNC mill machine to the point of 80%
By dudz in forum Conversion Build LogsReplies: 13Last Post: 20-03-2014, 06:44 PM -
Start of a new built.
By Tanky_Turk in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 06-03-2014, 09:26 PM -
WANTED: Milling machine head
By Ainis in forum Items WantedReplies: 0Last Post: 23-07-2013, 09:30 PM -
WANTED: home built cnc
By japcarmaniac in forum Items WantedReplies: 1Last Post: 24-04-2013, 02:35 AM -
Already built my machine.. but some pics of work etc
By Yohudi in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 31-08-2007, 06:15 PM
