Page 7 of 8 FirstFirst ... 5678 LastLast
  1. #61
    I too was worried, that my 5mm screws won't be good enough, especially when spending close to £2k on the build. But then there no point on wasting valuable sleeping time, lol. Just going to use what I have, and if its too slow, and whipping about, I'll buy the 10mm pitch and use these for my plasma, or laser, or 3d printer. Got a lot of plans lol.
  2. #62
    Hi, was just reading through your post and its helped me out a lot with design ideas. I'm still at the design stage at the minute, can't wait to get started on building.
    Just wondering how yours is going? Do you have any images and more advice - do's and dont's. cheers!
    Dan
  3. #63
    Hi Dan,
    I'm just waiting on the aluminium parts to get machined. To be honest, I'm not pushing on getting them done quickly, as I've got too many things on at the moment. That doesn't mean my minds not thinking about it, lol.
    Since I've decided to go with dual x axis drive, my PC case control cabinet is looking too small to squeeze another am882 driver in, and also the recent decision to go with an ethernet SS and PDMX 126 BOB. So another part on my shopping list was a PROPER control cabinet, which as of today, am the proud owner of a used 600mm x 400mm x 200mm electric enclosure with slotted cable trunking, on/off switch and safety locks. Bargain at £40 shipped. Everything should fit now considering its twice the size of my PC case.
ID:	8271Click image for larger version.
    As for advice, DON'T buy any electrical components till your machine is built. Mine are just sitting there, eating up their warranties.
  4. Quote Originally Posted by Iwant1 View Post
    Since I've decided to go with dual x axis drive, my PC case control cabinet is looking too small to squeeze another am882 driver in.
    May of missed this in your thread but why did you decided on 2 drives over the long belt option??
  5. #65
    After spending so many hours deciding between the two options, and after some emails with Jazz, I just bit the bullet and decided with dual drive. The main points in my decision were:
    with AM882 there wasn't any issue with the gantry racking from one motor stalling as they have stall detection alarms, and the machine will E-stop before any damage is done.
    Next, as for sync issues creeping in, Jazz says with descent drives this is drastically reduced compared to cheap Chinese drives. Obviously with one motor and belt its completely eliminated and is only a problem on very long jobs, which I doubt I'll be doing. Though you never know.
    Then with 2 motors tucked away in the corners, it keeps the far end of my router free from belts and motors and tensioning arrangements, allowing for sliding long materials through.
    With the long belt and one motor, I reckon a larger motor like a nema 34 would have been needed, and since I prematurely bought a nema 23, thought I'd use it on one side and buy another 23.
    Also I think the 23 motor can spin faster at the top end, which will be ideal for my incorrectly ordered 5mm pitch screws, when traversing.
    This is how I came to my choice, but it no big deal if I want to change change later. And I'm sure someone here will snap up my spare driver and motor, lol
    Adil
  6. #66
    I have been pondering over the 2 motors v 1 motor decision too. I think I will be going with the 1 motor option. You know you mention there may be issues with long jobs, what is the reason behind this.
    I wanted the ability to slide large boards through the machine but may settle for turning them through 180 degrees instead.
    Dan
  7. #67
    Quote Originally Posted by Danielroyal25 View Post
    From what I understand, long jobs are when you machine for 10+ hours without homing in between. Imagine one motor is losing a step here and there, and over a all those hours the missed steps could add up to a difference of a few mm's of one side of the gantry, taking it off square.
    Homing would normally square it up again, but I'm not sure why on long jobs, like 3d carving, why can't you program a homing function every hour, and then continue where it left off.
    Adil
  8. #68
    Bart's Avatar
    Lives in Krakow, Poland. Last Activity: 08-03-2016 Has been a member for 9-10 years. Has a total post count of 12.
    I don't want to hijack this post but i have a similar design and I'd like to use your experience.
    I've designed the frame etc. in inventor and from the simulation i get deflections smaller than 0,015 mm with the force of 500N excreted on a tip of an end mill. Thus, the design seems to be sturdy and good enough but I'm waiting for any suggestions.
    My questions...
    1. Chinese spindle - which one to chose
    There is plenty of different looking spindles on ebay and even more sellers so I'm not sure where to buy and more importantly which model. Which one do you have or which one you know is safe to buy.
    2. how to avoid two motors.
    I tried couple designs of frames to hold one ballnut for one ballscrew in the center under the table but it's hard to get small deflection without making it very heavy. Do you have some ideas how to solve it without 2 ballscrews and motors on each side?
    How is the solution, with line that winds up on a rotating drum, called?
    3. what's the free play on a linear rail's open bearings?
    Is there any free play on them, how much do they flex?
    Also I saw couple times that max speed for linear rail bearings is 5 m/s. What happens above that speed and how does it affect service life.
    4. whats the advantage of linear guidways over supported rails?
    They would cost me at least 2 times more. I've read the spec and according to it they don't deflect almost at all. What are the other advantages and are there any disadvantaged besides the price?
    5. End supports for ballscrew.
    I saw a design where instead of end supports fixed to the gantry or frame there where bearings directly fixed to gantry/frame. It seams that it might be stiffer and cheaper. What do you think of it?
ID:	9324Click image for larger version.
    Kind Regards
    Bart
  9. #69
    #1: This guy is ok. Most of them are the same spindle and probably out the same factory.?
    2.2KW WATER-COOLED MILLING AND GRINDING SPINDLE MOTOR WITH 2.2KW INVERTER VFD q3 | eBay
    #2: Honestly there is no solution to match driving from both sides whether twin ballscrews, R&P or belt drive it's by far the best and easiest way to get accurate stiff machine. The wire/drum is just a bodge and best doing it correctly first time.?. . You'll only end back there in the end.!!
    Unless your machine is narrow format, which it doesn't look, then single screw just won't work good. Making gantry wide helps but there's a limit before it gets unusable or feasible.
    #3 Can't answer that question without knowing which make and what size linear rails. What I can tell you is even the lower quality units are capable of handling forces far beyond what you throw at them or what your machine design will handle, so it will fail long before they do.!!
    #4: No contest here linear rails win hands down in every department by a very big margin. They can't be compared really in accuracy and performance terms.
    The other advantages are longevity, they will easily last several years longer than supported rails, even in very harsh conditions. Hassle free usage, fit grease occasionally and forget.
    Disadvantages over linear rails is they don't tolerate poor workmanship and misalignment.
    #5: Show us and will comment but until then not sure what you mean.?
    Now your design.?? . . . You have a problem Houston (several actually).!!! . . . . but this one Is a common mistake easily missed.!
    The linear bearings on the Y axis can't possibly be fastened like you have them drawn.? Chicken and egg problem.!! Fasten plate on one set and you can't access the bolts for the other bearings.!!
    I'd also consider using different thickness material for the Z axis.? Those thin plates, even with the bracing will resonate while cutting which will affect quality of finish. Don't rely to heavily on the Cad simulation, without inputting all the variables and cutting forces then it won't show this. I know from experience that if you plan on cutting hard woods or hard material like aluminium then your Z axis just isn't strong enough.
    Just remember no matter how well built or how strong or accurate the rest of the machine is it's the Z axis that takes all the cutting forces
    and if this flex's or resonates the rest don't matter a jot.!! . . . The machine is only has good has it's weakest link, this Z design is weak.!
    ( Also Don't rely on the Linear rail adding strength they don't really add much.!)
  10. #70
    Hi Adil, this is a very interesting build and a great deal of care has been give to getting the design right.
    One question regarding the electronics, do you have a wiring diagram/schematic that you are using? If you do, could post it up as I'm currently struggling with this.
    Jim
  1. CONVERSION: Re-Built a used CNC mill machine to the point of 80%
    By dudz in forum Conversion Build Logs
    Last Post: 20-03-2014, 06:44 PM
  2. Start of a new built.
    By Tanky_Turk in forum Gantry/Router Machines & Building
    Last Post: 06-03-2014, 09:26 PM
  3. WANTED: Milling machine head
    By Ainis in forum Items Wanted
    Last Post: 23-07-2013, 09:30 PM
  4. WANTED: home built cnc
    By japcarmaniac in forum Items Wanted
    Last Post: 24-04-2013, 02:35 AM
  5. Already built my machine.. but some pics of work etc
    By Yohudi in forum Gantry/Router Machines & Building
    Last Post: 31-08-2007, 06:15 PM
