    Hello all,
    I decided to do the version2 upgrade whilst v1 was still in the drawing stage. The main change was to go profile rails on all axis. I also changed the x axis steel rectangle box for 45x90mm ali extrusion as it looks simpler and more accurate to fix the profile rails onto. Same goes for the y axis ali box section except its 45x45mm extrusion. There are two qualities to buy extrusion at, light and heavy. What do most people go with.
    Anyways, here are some modified drawings. The first one shows the profile update and the x axis ball nut mount which now allows for adjustment. The middle pic shows how I intend on screwing the bk support block and z motor mount opposite each other. A screw will go from the bk side, through the z rear plate and screw into the motor mount. Hope that is strong enough. Last picture shows how the z plates will be machined to make registers for profile rails and carriages and also allow space for moving parts.
ID:	6370Click image for larger version.
Name:	motor mount.jpg
ID:	6371Click image for larger version.
Name:	z axis machining.jpg
    Thanks for looking
    Adil
    Definatly use the 'heavy' extrusion if you can afford it. What profile rails are those and what size...hiwin?
    Quote Originally Posted by Iwant1 View Post
    It probably would be strong enough, but it would be good to have a second support for the motor mount, like this one I made earlier:
Name:	DSC08894 (Medium).JPG
ID:	6373Click image for larger version.
Name:	DSC09619 (Medium).JPG
    Much more important though is you need some method to tension the belt. The easiest way is to instead of having simple holes in the motor mount, make them slots so you can pull the motor/belt tight then tighten the bolts - again like in the one above. This also allows different pulley sizes to be used without changing the belt, which could come in useful.
    Edit: Just to add, moved sketchup discussion here as requested.
  3. The Following User Says Thank You to Jonathan For This Useful Post:
    Thanks Jonathan, good advice as I will be putting larger pulleys on the motor side. Now I can do it with the same belt.
    Yep going for Hiwin, as I can't find any suppliers of new THK or NSK. I'm using 20mm profile rails and the carriages have 4 rows of balls.
    I've redrawn the motor mount, but decided not to go with a full plate on the back of the z axis. Just extra weight for the gantry to carry. Can be easily added later if needed.
Name:	z motor mount.jpg
  5. #4
    15mm rails will be plenty strong enough. The load ratings of 15mm are several times what the machine will require... considering you were happy with round rails just a few days ago, I don't think there's much point using bigger than 15mm since the difference in stiffness between 15mm and 20mm profile rails is tiny compared to the difference between profile rails and round rails. Many much larger industrial machines use 15mm rails.
    If you do add one it needn't be thick - 10mm would be fine as it's only to stop the joint between the plates that the Y and Z bearing blocks mount on bending.
  6. #5
    Know this is a bit late 3 weeks after posting but I've been asked for some input by Adil and was looking over the build again and spotted this comment.!!
    Jonathan never have understood why you use this rear plate in the way you do because that rear plate on the back add's very little protection against the joint between Y axis bearing plate and Z axis rear plate bending in the vertical.?
    The only forces that apply here are vertical force applied from one side and the overhang distance from the Y axis bearing plate to Z axis rear plate is nothing.? possibly few MM's. So the chances of that joint bending are zilch and if the forces were great enough to bend that then the rest of the frame and gantry are in big trouble and 99% sure something else would be bending/breaking much sooner.
    Your design is an open ended box with very little strength in the vertical direction and if enough vertical force is applied at one side the other side will deflect in a similar manner.!
    If you want to brace for that movement then plates on the side bolted into both plates would be much better and could be much thinner and still give far better bracing support than those backplates.? This back plate just add's weight and cost IMO for not enough gain and isn't required.!
  7. #6
    The back plate is there because otherwise the Y-bearing mount plates are effectively cantilevered, hence in my opinion it's worth having something to reinforce these joints. However I agree that plates on the sides, as you suggest, would offer much better reinforcement, but this would increase the width of the Z-axis and loose some travel on Y, assuming the width of the Z-axis has already minimised. The plate certainly doesn't need to be the same thickness as the other parts, it was just convenient for the one in post #20 since I didn't have much of anything less than 20mm in stock, plus it was an easy way to support the motor mount.
    Iwant1: How far are you with the design / build now?
  8. #7
    Not really much of a cantilever is it at 1 or 2mm and still your not supporting the cantilever but have created double cantilever ~(see-saw with bearings as pivot.!) with no bracing support.!!
    Plate thickness doesn't matter could be 50mm or 5mm it's still adding very little vertical bracing support.? Plus it restricts the back side of the gantry so cable chain etc is more difficult to run.? . . . Like say IMO it's heavy, expensive, restrictive and unnecessary. . . Each to there own.!!!
  9. #8
    Lots of changes have been made, its an ongoing process with every new thread on here, regarding motor drives and the strongest gantry designs. It gets so confusing. So far, I've managed to sell off my supported round rails and have already bought profiled rails for all axis, got a good price so went with 20mm. I also sold my 50v power supply and got a 2x24v toroidal coil from which I will build my 70v supply. And now I'm thinking about selling my pm752's for the digital am822's. I Know I know, I should have waited before I bought all the wrong components, but at the time, 2010, these were the most popular components. 2 years later I now want an even better machine than I originally thought of.
    Anyway, I've also been busy buying all the electronics for my control cabinet. I will be using an old pc case, and filling it with goodies. Around £300 have been spent on all the electric bits, including screened cables, regular 16/0.2 cables, e-stops, limit and homing switches, relay gear, toriodal coil and electronics to rectify it, 12v and 24v psu's, small consumer unit, a selection of plugs and sockets, and the list goes on.
    Chai a even sorted me out with a good price for a 2.2kw spindle and vfd, so I went and got some cooling components for this too. Mainly, a water pump with reservoir, double aluminium heat exchanger, 2 120mm pc fans and grills to go with the exchanger. Once these bit arrive, then I will see what size pvc hose I need.
    I've been taking pic's of the control cabinet getting made and will post soon.
    Adil
  1. CONVERSION: Re-Built a used CNC mill machine to the point of 80%
    By dudz in forum Conversion Build Logs
    Last Post: 20-03-2014, 06:44 PM
  2. Start of a new built.
    By Tanky_Turk in forum Gantry/Router Machines & Building
    Last Post: 06-03-2014, 09:26 PM
  3. WANTED: Milling machine head
    By Ainis in forum Items Wanted
    Last Post: 23-07-2013, 09:30 PM
  4. WANTED: home built cnc
    By japcarmaniac in forum Items Wanted
    Last Post: 24-04-2013, 02:35 AM
  5. Already built my machine.. but some pics of work etc
    By Yohudi in forum Gantry/Router Machines & Building
    Last Post: 31-08-2007, 06:15 PM
