Thought I'd put up my latest renderings of how I want my router built. I went with the L extrusion gantry design which came out on top in this thread, effect-forces-gantry-cross-sections.
A big thanks to Dean for helping me along the way, with which I'm now set on a final design. The drawing mostly concentrates on the gantry and z axis. The x axis is not to scale , just for visual purposes of how the components connect.
So, I've got most of the electronic bits, my profiled rails are on route, and the next thing on my order list is the extrusion. The ali plate order needs some jiggling as I want all small parts to fit on one large sheet, so its easier for machining.
The frame, not pictured here, is still made from welded and bolted steel box section.
The x axis drive will also be upgraded from 1 motor and a long belt, to 2 motors and 2 short belts, as my new drivers have stall detection. Will need to buy the extra motor and driver.
ID:	6823Click image for larger version.
ID:	6822Click image for larger version.
ID:	6821Click image for larger version.
ID:	6820Click image for larger version.
ID:	6819Click image for larger version.
