I'll be buying from KJN KJN - Suppliers or Aluminium Profile and Accessories since they do a 45x90 profile unlike Value Frame whose closest is 40x80 profile. I went with bigger is better, also from reviews I've seen on here about their good service and accurate cuts, I'm sold.
Don't for get to order all the extra connecting elements like T nuts and screws when you place the order with your chosen supplier. Also if you go with profile rails rather than supported rails you need to check the maximum socket head screw that will fit in the rail pocket, as you will have to get appropriate T nuts. For the profile rails I have, I found an M6 thread will fit but its head is fractionally too big, so had to use M5. For connecting ali extrusion profile with other I'll be using M6 Screws and nuts.
Hope it helps, Adil
CONVERSION: Re-Built a used CNC mill machine to the point of 80%
By dudz in forum Conversion Build LogsReplies: 13Last Post: 20-03-2014, 06:44 PM -
Start of a new built.
By Tanky_Turk in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 06-03-2014, 09:26 PM -
WANTED: Milling machine head
By Ainis in forum Items WantedReplies: 0Last Post: 23-07-2013, 09:30 PM -
WANTED: home built cnc
By japcarmaniac in forum Items WantedReplies: 1Last Post: 24-04-2013, 02:35 AM -
Already built my machine.. but some pics of work etc
By Yohudi in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 31-08-2007, 06:15 PM
