11-08-2012 #10
Know this is a bit late 3 weeks after posting but I've been asked for some input by Adil and was looking over the build again and spotted this comment.!!
Jonathan never have understood why you use this rear plate in the way you do because that rear plate on the back add's very little protection against the joint between Y axis bearing plate and Z axis rear plate bending in the vertical.?
The only forces that apply here are vertical force applied from one side and the overhang distance from the Y axis bearing plate to Z axis rear plate is nothing.? possibly few MM's. So the chances of that joint bending are zilch and if the forces were great enough to bend that then the rest of the frame and gantry are in big trouble and 99% sure something else would be bending/breaking much sooner.
Your design is an open ended box with very little strength in the vertical direction and if enough vertical force is applied at one side the other side will deflect in a similar manner.!
If you want to brace for that movement then plates on the side bolted into both plates would be much better and could be much thinner and still give far better bracing support than those backplates.? This back plate just add's weight and cost IMO for not enough gain and isn't required.!
CONVERSION: Re-Built a used CNC mill machine to the point of 80%
By dudz in forum Conversion Build LogsReplies: 13Last Post: 20-03-2014, 06:44 PM -
Start of a new built.
By Tanky_Turk in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 06-03-2014, 09:26 PM -
WANTED: Milling machine head
By Ainis in forum Items WantedReplies: 0Last Post: 23-07-2013, 09:30 PM -
WANTED: home built cnc
By japcarmaniac in forum Items WantedReplies: 1Last Post: 24-04-2013, 02:35 AM -
Already built my machine.. but some pics of work etc
By Yohudi in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 31-08-2007, 06:15 PM
