27-01-2013 #25
You can't say that without knowing what's being done with machine.? 1610 doesn't work better it just allows higher speeds and if those speeds aren't needed then there's no point.! . . . Infact it's wasted resolution/torque.
That said I didn't realise Adil bought 5mm pitch screws for all axis and believe he mainly wants to cut wood in which case 10mm pitch would have been better suited. But as we know it's not the end of the world and with belt gearing easy sorted.
Regards Micros stepping then Really you shouldn't consider micro stepping for resolution it's biggest help is with smoother operation of the motors at lower speeds and like Jon says it helps with resonance. Just remember the higher you set the resolution the harder the Parallel port has to work putting out more pulses's for the same movement so you'll need a good PP port other wise you could easily lose steps. More than 2000(10x) micros steps is pointless really has most of the Cheaper motors can't resolve to higher than that.
CONVERSION: Re-Built a used CNC mill machine to the point of 80%
By dudz in forum Conversion Build LogsReplies: 13Last Post: 20-03-2014, 06:44 PM -
Start of a new built.
By Tanky_Turk in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 06-03-2014, 09:26 PM -
WANTED: Milling machine head
By Ainis in forum Items WantedReplies: 0Last Post: 23-07-2013, 09:30 PM -
WANTED: home built cnc
By japcarmaniac in forum Items WantedReplies: 1Last Post: 24-04-2013, 02:35 AM -
Already built my machine.. but some pics of work etc
By Yohudi in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 31-08-2007, 06:15 PM
