  1. #15
    Quote Originally Posted by jonbabbz View Post
    Dont worry mate, happy for the info. This one was recommended by Jonathan in another thread. Apparently it doesn't require one, (MB256)? I wasn't so sure - especially with the high amount of current that will be running through it. I suppose its better to be safe than sorry. Ill get one added. Cheeeeeeers
    I use the same one and it gets warm, but not hot or anywhere near it's temperature rating so I've not put a heatsink on mine. The peak current running through it is quite high, but here it's the mean current that matters (as that determines the power dissipation) and that is much lower. However if you've got a suitable heatsink lying around then you might as well use it.
    Here I'm running one stepper driver with a 3Nm motor at 4.09A from my lab PSU for testing, note the current:
  1. FOR SALE: Homemade 'Coventry' Type Easy Change Toolholders
    By jamesgates1000 in forum Items For Sale
    Last Post: 04-12-2015, 09:22 PM
  2. Homemade 3d laser scanner and free software.. looks really good
    By Fivetide in forum Laser Machines & Building
    Last Post: 03-09-2012, 01:09 AM
  3. Homemade CNC Project Help
    By chaslam07 in forum Gantry/Router Machines & Building
    Last Post: 04-04-2012, 11:53 AM
  4. BUILD LOG: Few pics of my homemade CNC mill
    By wiatroda in forum DIY Router Build Logs
    Last Post: 18-02-2011, 09:43 PM
  5. Homemade desktop CNC - cutting 0.8mm mild steel out the question?
    Last Post: 16-04-2010, 09:37 AM
