Thread: Spindle to uniport
Sounds like It will be the relay delay spinup/down settings inside Mach. Go to Ports & pins spindle setup and under the general parameters set the CW delay spinup = 0 or a low number like 1 same for CW spin down.
If that doesn't work then it's in the VFD settings but I'd ahve to go have a look at the manuel to find it.
25-07-2012 #2
This could be that you haven't got the charge pump setup on BOB or should say override, so when Mach E-stops and drops the charge pump signal it doesn't see it and keeps going for a while.? . . . Not sure on this thou.!!
Edit: On reflection scrap that idea it wouldn't do that.!!
25-07-2012 #3
Awesome guys thanks!
25-07-2012 #4
25-07-2012 #5
I ain't tried it yet just saying thanks in advance...... But now you got me thinking of it I need to go down and try it but wife ain't gona be happy #singleman = more money to spend on machine! haha
25-07-2012 #6
25-07-2012 #7
Lol. Nah that CW spin up did big do te trick. Just looking in the VFD now.....
25-07-2012 #8
Can't seem to find it in the manual either
25-07-2012 #9
Ok brain fart.!! . . just realised you actually do want a delay in the General parameters.? What it does is delay the movement commands giving the spindle time to spin up.!
So set it to 4 or 5 seconds and it should do the trick.?
Edit: Also are you sure the codes OK.? if there's Z movement commands before M3 then it won't start until Z command finish's so it will be hitting work.?Last edited by JAZZCNC; 25-07-2012 at 07:15 PM.
25-07-2012 #10
Yeah the z moves befor the spindle which I correct, but by the time it's got to its location the z is down and still has not spun up yet maybe half a second off...
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
CNC Spindle Repair and Spindle Replacement for any Machine of any Manufacturer
By spindeldoctor in forum Manufacturer NewsReplies: 0Last Post: 13-11-2013, 07:50 PM -
eBay: uirobot stepper drivers and uniport 2 board
By andrewuk in forum Items On eBay UKReplies: 0Last Post: 11-09-2013, 09:47 AM -
Spindle lock mechanism for 2.2kW china spindle
By Jonathan in forum Generic Chinese SpindlesReplies: 8Last Post: 13-08-2012, 08:39 PM -
Uniport and limit switches.
By D-man in forum General ElectronicsReplies: 14Last Post: 13-02-2012, 11:37 PM
