Ok complete brain fart (and a follow through!!) I set the settings to 15. Now what I have done wrong was I was looking for the delay from the moment I pressed start. I'm a tool I know!
So jazz, what happens now is.....
Press start - Z moves up. Once it reaches safe Z the spindle kicks in, and holds its position for 15 seconds (lol I will change that) after the delay it then proceeds to do its job. All I need to do it edit that delay and were good.
Now.... How did you say I go about getting the spindle to shut off after job as you said you could not see the command.
