    i am indeed running the 4.2A motors. If you could post the circuit that would be great, I've searched for it but couldn't find it. Thankyou
    Quote Originally Posted by jonbabbz View Post
    Couldn't find it either, so just drew this:
    (next time I'll find the mouse..)
    Top one if you get 24V or 25V transformer (preferable), lower one if it's 48V or 50V. The capacitor needs to be 10000uF minimum, ideally a bit more so three of these in parallel is good (assuming you get transformer from Rapid, otherwise might be cheaper elsewhere, eBay, Farnell etc). This bridge rectifier is good as it wont need a heatsink. So about £60 in total...
    If you got the bits posted to me I'd feel guilty charging more than a fiver to wire it up as it's less than 10 minutes work.
    As Jazz just implied, you could use terminal block and crimp connectors instead of soldering.
  1. NEW MEMBER: newbie from bristol soon to be up and running
    By uppy121 in forum New Member Introductions
    Last Post: 01-04-2013, 12:38 AM
  2. PS806-5 Power Supply
    By Washout in forum General Electronics
    Last Post: 11-11-2012, 03:07 PM
  3. axis not moving when running code
    By geny in forum Computer Software
    Last Post: 21-10-2012, 08:02 PM
  4. 4th Axis running as CNC lathe using milling machine
    By Jonathan in forum Milling Machines, Builds & Conversions
    Last Post: 21-08-2011, 10:34 AM
  5. Running costs of CNC machines?
    By .kyle in forum General Discussion
    Last Post: 19-05-2011, 08:05 PM
