Not really Gary.!! . . . . To run 4 x 4.2A motors he'll need 2 x PS806 thats £204 plus del For less than 1 PS806 he can build a supply that will easily give what he needs and still have change to buy a small 5V 1A reg supply.!
Inrush is not a problem @ 600Va and easy enough to build an inrush circuit if really needed.! ( Which it won't be in most case's)
14-07-2012 #2
Don't need much change for that :)
http://www.ebay.co.uk/itm/UK-DC-5V-1A-Switching-Power-Supply-adapter-100-240V-AC-Promotion-/200791372447?pt=UK_Sound_Vision_Other&hash=item2ec 019329f#ht_3691wt_1037
I guess.
14-07-2012 #3
Was thinking something a bit easier and neater than that.!!
http://www.ebay.co.uk/itm/DC-5V-5A-R...item2a1fbcca51
Edit: I've had 2A version of these for £5 before this was just an example.Last edited by JAZZCNC; 14-07-2012 at 01:00 AM.
14-07-2012 #4
What is said was the PS806 is a far better solution to the PS705, not just because of the size difference but also because its linear and linear power supplies are far better suited for stepper and servo applications.
The advantage is that the PS806 can handle quick changes in current draw a lot better than the PS705.
Looking at the spec, the PS806 is cutting it very close and ideally you would need about 8-10A of peak current, however I have run 3 X 6.2A motor from one of these with no problem at all and the voltage is still in 60V range.
Next week i will power one up with 4 AM882 and SY60 motors and monitor the current and voltage and report back to you.Last edited by Gary; 14-07-2012 at 10:02 AM.
Visit Us: www.automationshop.co.uk
NEW MEMBER: newbie from bristol soon to be up and running
By uppy121 in forum New Member IntroductionsReplies: 16Last Post: 01-04-2013, 12:38 AM -
PS806-5 Power Supply
By Washout in forum General ElectronicsReplies: 7Last Post: 11-11-2012, 03:07 PM -
axis not moving when running code
By geny in forum Computer SoftwareReplies: 0Last Post: 21-10-2012, 08:02 PM -
4th Axis running as CNC lathe using milling machine
By Jonathan in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 21-08-2011, 10:34 AM -
Running costs of CNC machines?
By .kyle in forum General DiscussionReplies: 1Last Post: 19-05-2011, 08:05 PM
