Hi
Do you know what drivers you have in the machine at the moment?
If the drivers are ok and will take step and direction signals it might just be a case of a new breakout board a bit of re wiring and using Mach or Linux to do the control.
andy
17-07-2012 #2
Hi Andy,
All the electrics seem to be integrated. The drivers are on one board that plugs into another board. When you power up the machine it should zero itself. It did this a few times and then stopped and now when I fire it up it does nothing. I've had the machine a couple of years now and managed to nothing with it except get frustrated and spend lots of money getting electricians to look at it.
I thought if redoing the electics wasn't prohibitively exspensive, it would be my best option, at least I would have a better undestanding of how everything works and I could at least get it to run on mach3. But I'm floundering in the dark a bit as to what I would need to get as in drivers , power supplies etc.
Thanks,
Paul
Stepping Motors & Drivers
By irving2008 in forum Stepper & Servo MotorsReplies: 3Last Post: 28-04-2015, 09:37 PM -
Matching Drivers with Steppers
By hoppo in forum Motor Drivers & ControllersReplies: 4Last Post: 21-11-2012, 01:19 PM -
2x Motors, 2x drivers. How about breakout?
By Tenson in forum Motor Drivers & ControllersReplies: 2Last Post: 20-09-2012, 03:21 PM -
CNC rebuild ,matching drivers to motors
By 2006Nobull in forum Electronic Project BuildingReplies: 1Last Post: 17-07-2012, 04:09 PM -
Motion Control drivers and motors
By bruce_miranda in forum Motor Drivers & ControllersReplies: 71Last Post: 27-08-2009, 09:40 AM
