joe harris
thanks very much for the "View>component edit>hide rest of model to fully isolate the element so you can work on a part that would otherwise be hidden - can be a life saver some times! (hope i'm not teaching you to suck eggs but someone is bound to find that tip useful.)"
It makes life so much easier
09-08-2012 #2
24-07-2012 #3
I doubt the measurement box is capable of using operators with the push/pull tool.
I would use the measurement tool to mark out the full dimension you're after, then use that as a guide to push/pull the surface to.
So for example if you got your extrusion at 167mm length and you want it 400mm long. Select the measurement tool, click at one corner of the extrusion, then move the mouse in the direction you want to go in and enter 400 in the measurement box. That gives you a reference to take the push/pull operation to. No complex maths involved, lol, just a few extra clicks.
24-07-2012 #4
25-07-2012 #5
Thanks... At last I'm making some rewarding SketchUp progress.
Have invested in a cheap calculator as Joe suggested, which seems better than using Mobile/MS-Calculator/MS-Excel when necessary. Am finding using Scale rather than Push/Pull easier to use accurately.
Was finding it more than a tad painful aligning the components/groups of 45x90 extrusions with the rounded corners, so have instead initially and quickly built the base with components that are simple 45x90 box sections.
Have structured things such that each of my components is created correctly-pre-oriented as a separate model and then imported into the main design model, so I can incorporate changes such as changing the box-sections to extrusions simply by reloading from a different model file... Eureka Adil!
It takes time to sink in... but I am getting there.... one wee step at a time....
29-07-2012 #6
Hi, how do you join the face of one component to the face of another in sketchup, i.e ballscrews to a flat surface etc.
29-07-2012 #7
The best way is to group your item so you are dealing with a single part. Select the point to join. Probably the centre of the ballscrew. If you do not have a ready position to pick then draw in extra lines that give you an intersection or end point on your component. These can be removed later. Once you start the move you may have to re-orientate your view.
The more I know, I know, I know the less. (John Owen)
29-07-2012 #8
29-07-2012 #9
The snap is when your cursor selects a point such as an intersection, midpoint, centre of a circle, end of line or a vertex. So select a snap point on the moving part and move it to the other snap point. If you want to go to the centre of a square block there is not a snap point. So draw a line from each opposite corner and where they cross will now have an intersection. Use this to snap to and delete the lines when done.
It really easier to do then explain. Keep trying.
BruceThe more I know, I know, I know the less. (John Owen)
29-07-2012 #10
Something that took me ages to get out of the habit of, is dragging the object you are moving with the mouse button held down - just click once to start moving and click again when (and if) you get the object to where you want it to go. Also holding down the up, left and right cursor keys when moving restricts movement to the blue, green and red axis respectively - I often have to make multiple moves bound to a couple of axis to get an object to where I want it using this method, but at least it's not so random as when the cursor is trying to snap to various geometry as Sketchup makes a best guess at where you are aiming for.
Another little trick I use alot is when rotating a grouped object and I can't get the ptrotractor in the right plane is to draw a quick cube next to the object to be rotated, select the group to be rotated, hover the prtractor over the cube face that corresponds to the plane of rotation then hold shift down and it will stick in that plane whilst you move the protractor back to the point of rotation on the group to be rotated, then do as normal.
Oh if you haven't already found them get the Cleanup Tools addon for Sketchup - its somwhat aimed at games 3d modelling, but is useful for automatically tidying up reversed faces, co-planar faces, orphaned line vectors/edges etc http://forums.sketchucation.com/viewtopic.php?t=22920
Hope that helps and isn't teaching to suck eggs..
Chris
Sketchup
By mekanik in forum SketchupReplies: 5Last Post: 06-11-2013, 09:34 PM -
Just a thought, a google map of member locations
By D-man in forum General DiscussionReplies: 37Last Post: 09-04-2013, 02:38 AM -
Google Sketchup >> Vectric VCarve
By kingcreaky in forum Computer SoftwareReplies: 9Last Post: 09-03-2013, 07:42 PM -
Google Sketchup components?
By mocha in forum SketchupReplies: 22Last Post: 07-08-2012, 11:49 AM -
Converting sketchup to dxf
By motoxy in forum SketchupReplies: 3Last Post: 08-07-2012, 12:04 PM
