    when i picked up my boxford lathe it came with an interesting single phase motor that was obviously not suitable for the lathe
    the spec...
    240v single phase
    2hp
    9700RPM!!
    i have never seen a single phase motor with that high an rpm rating and it made me wonder
    what would this motor be used for?
    any ideas?
    Odd size for an ac motor but ok for a dc one. Photo please.
    How are you getting on with the boxford? I bought a Blomqvist Model A, copy of the Boxford, a while ago and have rebuilt the gearbox earlier this year and I have just done the apron gears. Just started stripping the rest down for a re-paint.
    If it's a single phase motor then it would either be run on 50Hz or 60Hz, so for 2-poles that's 3000rpm or 3600rpm. The lower the number of poles the higher the speed, but you can't have less than 2-poles therefore( Web-goblin said) it must be a DC motor. Or if you're extremely lucky I guess it could be a servomotor...
    well... here are some pictures of the motor in question
    picture quality isn't great as the only camera i have is my trusty but outdated nokia 6300
ID:	6393Click image for larger version.
    web goblin, the boxford is slow progress at the moment but im aiming to get it finished asap
    just noticed that the pic of the spec plate is indecipherable so i wrote down what it says
    G&C machines
    S.M.E. division
    made in the uk
    AC series motor
    INS. CL h
    KW 1.5
    VOLT 230/240
    AMPS 8.9
    HZ 50
    PHASE single 1
    REV/MIN 9700
    RATE sfr 30 min
    FRAME 9085l
    SERIAL NO. 630 cbj 5621 82
    Lives in East Lothian, United Kingdom. Last Activity: 18 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    It'll be some kind of commutator/brushed motor, not a standard AC induction motor.
    interesting, but what application needs 9700rpm? it is also extremely loud (but i guess thats inherent of its nature)
    any ideas on what i could use it for?
    I've got to admit, I'm struggling to think of anything that would need 1.5kw (aprox. 2hp) at that speed, or what you could use it for!
  9. It sounds like a series wound ac motor / universal motor?
    open it up, so see it the armature and the field are wound in series?
    Not seen one for years.
  10. Quote Originally Posted by m_c View Post
    Since its limited to 30min operation, I'd hazard a guess at some sort of cooling/pumping/extraction process.
  1. the mystery of the wonky corners
    By kingcreaky in forum Machine Discussion
    Last Post: 06-05-2014, 03:58 PM
  2. Replies: 2
  3. Replies: 3
    Last Post: 24-11-2013, 02:36 PM
  4. Mystery Profile, Please Help!
    By floydpjasper in forum Machine Discussion
    Last Post: 10-03-2012, 06:27 PM
  5. servo motor as spindle motor
    By Scott in forum General Discussion
    Last Post: 03-10-2010, 06:42 PM
