Thread: Delrin & Nylon S & F please
Really depends on the size and type of cutter you plan on using.?
Also whether you want to cut full slot IE: cutter enclosed both sides like when profiling out of sheet, or if your mainy cutting with a step over.? The step over amount will greatly affect feed rates.
The strength of your a machine will also play a part.!
I don't cut much plastics but here's some figures that G-wizzard spat out for hard plastics.! I would use these a guide only and adjust to suit your machine.
Here's a few based on 50% cut diameter for DOC.
HSS 3m 1 flute= DOC 1.5mm FR 1200mm/min RPM 16200
HSS 6mm 1 flute= DOC 3mm FR 1050mm/min RPM 8100
HSS 3m 2 flute= DOC 1.5mm FR 2350mm/min RPM 16900
HSS 6mm 2 flute= DOC 3mm FR 2100mm/min RPM 8100
Carbide 3m 1 flute= DOC 1.5mm FR 1400mm/min RPM 23400
Carbide 6mm 1 flute= DOC 3mm FR 1250mm/min RPM 12000
Carbide 3m 2 flute= DOC 1.5mm FR 2800mm/min RPM 23400
Carbide 6mm 2 flute= DOC 3mm FR 2500mm/min RPM 12000
Hope this helps.
CNC Routing Nylon 6 Material
By Steff in forum General DiscussionReplies: 5Last Post: 20-10-2012, 11:39 PM -
RFQ: Bracket parts from Nylon
By egimson in forum Projects, Jobs & RequestsReplies: 4Last Post: 18-04-2012, 12:20 AM -
RFQ: Parts CNC machined from Nylon
By egimson in forum Projects, Jobs & RequestsReplies: 3Last Post: 02-04-2012, 08:40 PM -
WANTED: Roller end caps from pvc or nylon Help!
By stevedunn in forum Items WantedReplies: 10Last Post: 19-09-2011, 10:09 PM -
RFQ: Delrin drive nut (lee)
By progomez in forum Projects, Jobs & RequestsReplies: 29Last Post: 14-10-2009, 10:00 PM
