    Hi all.
    I got myself a second hand Blomqvist lathe a while ago and have gotten round to the rebuild stage on it. Heres a pic of the headstock end minus the guard before any work was started.
    Earlier this year I had stripped the gearbox down and had some new gears made for it to get it working properly again. Some of them were quite badly worn and one was slightly mangled. I think it had not been fully engaged at some point.
    The gearbox has been rebuilt and has been tested as working fine. I have stripped down most of the remaining parts now and cleaned the grease and crap from them and scraped the loose paint from some of the parts. I also have a couple of bags of bits that I need to make sure I dont lose somewhere.
ID:	6412Click image for larger version.
ID:	6411Click image for larger version.
ID:	6418Click image for larger version.
    I also had some problems with the apron. The power feed for the cross slide was not engaging so I have also stripped this down and fixed it and reassemble it ready for painting
    I did find a problem with the compound rest base. At some point the thread for the base clamp has been stripped so this had to be replaced with a recoil. Hopefully this will be ok.
ID:	6414Click image for larger version.
    The rest of the parts ready for cleaning then paint.
    The base and bed.
    Cleaning the crap out of the bed. There was quite a bit of it jammed inside the bed under the headstock.
ID:	6422Click image for larger version.
    I will be painting it a different colour from the original green, it will be a blue/grey I think.
    Hopefully this will be a bit quicker than my router build.
    I will post some more photos as work continues.
    Lots of the mechanical bits looks like Boxford's... :-) This should be fun!
    The Boxford and the Blomqvist are both copies of the South Bend. It is very similar to the boxford and I believe quite a few of the boxford parts will fit the Blomqvist as well.
    I have done a bit of work on this mainly repainting at the moment. Quite a few parts have been undercoated but I have managed to get the enamel coat on the base and tray. The photos show the undercoat and one coat of enamel on the base.
    A second coat of enamel has been applied but I dont have a photo at the moment.
    My Centec 2A has arrived so I need to extract me finger and get this done so I can get started on the Centec.
ID:	6732Click image for larger version.
    looking good!
    there's something so satisfying about seeing a crusty old machine given a lease of new life
    looking forward to seeing a rebuild thread for your 2A, il be doing one for my no2 when i finish the boxford
  6. Quote Originally Posted by jonnydeen View Post
    looking good!
    I agree, dont own a lathe myself but would love a project like this that is "doable" to the end. Keep up the good work Goblin im also following with intrest, when i grow up i may also follow the same path rather than buy a modern unit :).
    .Me
  7. Looking good bud, im in the middle of a lathe rebuild i got the lathe of ebay. i didnt take any pics of the strip down. but heres a pic of it before and when i am now with it!
    Before
    So far..
    Quote Originally Posted by AdCNC View Post
    Now that is a different ball game mate ! :-) Colchester ! I'd love to have one of these... But no room for that unfortunatly.... :-(
    The colchester is a great bit of kit. I cant get one of them in either:-(
    Right I have managed to get some time on the lathe and things are going well albeit a bit slow.
ID:	6936Click image for larger version.
    Most of the headstock has been refitted as is the tailstock.
    Apron is back on but I am waiting on the paint to dry to get the rear support fitted and get it set up again.
ID:	6934   Click image for larger version.
  1. Pacer compact rebuild
    By GEOFFREY in forum Gantry/Router Machines & Building
    Last Post: 26-12-2020, 08:27 PM
  2. REBUILD: Boxford Model B lathe rebuild
    By jonnydeen in forum Lathe Rebuild Logs
    Last Post: 16-07-2018, 08:48 AM
  3. REBUILD: Hardinge HC rebuild
    By northumbrian in forum Lathe Rebuild Logs
    Last Post: 21-02-2017, 12:07 PM
  4. Centec 2A rebuild
    By Web Goblin in forum Gantry/Router Machines & Building
    Last Post: 02-04-2013, 08:41 PM
  5. NEW MEMBER: New member wants to rebuild.
    By black5f in forum New Member Introductions
    Last Post: 21-06-2010, 11:38 PM
